We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I...
If you have the option of ordering 50 amp on the trailer go with it, you won't regret the decision should or when you need to run 2 AC's. We run our rig on 30 most of the time mainly because the 30a cord is easier to manage and there's only 1AC unit but, if the coffee pot, H/W heater and microwave are called to action at the same time, we trip the breaker. Using the 50a solves that and avoids the potential of low voltage to the AC which could be a bigger problem.
