laknox
Apr 07, 2015Nomad
30 amp / 50 amp
We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I...
ford truck guy wrote:laknox wrote:
We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I upgrade to the 15k AC will I =need= 50 amp or is that just "belt and suspenders" for a single AC. Second question; if I have the 15k AC and get the 50 amp service, can I use a 30 amp cord until such time as I add a 2nd AC and would be required to use the heavier cord? Third question; would I simply just be better off using 50 amp from the get-go, even with only 1 AC?
Lyle
IF you have any thoughts of ADDING the second AC.. you must go with 50 amp if you want to run them together.. My thoughts are that its kind of senseless to have 2 AC's and not be able to run them together.
When I run my FW off my 2 generators (in parallel) , I use the smaller 30 amp cord..
