laknox
Apr 07, 2015Nomad
30 amp / 50 amp
We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I...
RustyJC wrote:..CA Traveler wrote:laknox wrote:Yes plus you could make a 30A cord with a 50A female end that plugs into the rig side, hence no need for adapters etc.
I think you all have answered my question. I can likely get by on 30A with 1 15k AC and watching my power consumption, but I should carry both 30A and 50A cords...just in case. :-)
Lyle
Or, if your 50 amp rig has a 125/250 VAC 50 amp twist-lock receptacle that the power cord plugs into, you could use an adapter like THIS in conjunction with a 30 amp extension cord. I use this adapter to connect 2 paralleled Yamaha EF2000is generators with 30 amp output carried in the bed of the truck to the 50 amp twist-lock generator receptacle on the front of the 5th wheel to run one 15K BTU A/C to precool the 5th wheel on the road in hot weather.
Rusty
