laknox
Apr 07, 2015Nomad
30 amp / 50 amp
We're considering a new FW and a couple of the options are upgrading the single AC to 15k with 2nd AC prep (I believe the prep is standard). There is also a 30 to 50 amp option. First question; if I...
CA Traveler wrote:
I have 3 15A arc fault CBs for the bedrooms and probably 14ga wire.
And one 15A CB with 14 ga wire with 8 plugs and 270' of wire. It's not hard to imagine what happened when I tried to use my saw on the last plug. No problem using the radio and other light loads. I was sure this was a code violation but there is no restriction on wire length.
