avvidclif1
Nov 15, 2016Explorer
Lantley wrote:Grady23 wrote:
Anyone ever install a separate circuit on a remote breaker box for a 110 service? This was a recommendation from a mechanic working at a well known camping center. Then the bedroom A/C would be on its own 110 circuit and plugged in to the 30 Amp for the main 5th and a sep heavy duty extention on the post
This ^^^^ is a very viable idea.
THe gadget below is designed to do just that it will allow you to run both AC's on a 30 amp site
Check it out
I have an RV SafePower Switch. It allows me to run both AC's on a 30 amp site. Work like a champ
How does it hook up? It looks like a manual transfer switch that's very expensive.
They make a dongle that plugs into the 30a connection and also the 20a on a regular power pole but from what I have heard if the pole has a GFIC they don't work. OR if the pole only has 30a going to it.
https://www.amazon.com/Camco-55025-PowerGrip-Maximizer-Adapter/dp/B0024E70L2
About Fifth Wheel Group
