Lantley
Nov 15, 2016Nomad
Coach-man wrote:Lantley wrote:Grady23 wrote:
Anyone ever install a separate circuit on a remote breaker box for a 110 service? This was a recommendation from a mechanic working at a well known camping center. Then the bedroom A/C would be on its own 110 circuit and plugged in to the 30 Amp for the main 5th and a sep heavy duty extention on the post
This ^^^^ is a very viable idea.
THe gadget below is designed to do just that it will allow you to run both AC's on a 30 amp site
Check it out
I have an RV SafePower Switch. It allows me to run both AC's on a 30 amp site. Work like a champ
The problem with that, is most 20 amp outlets are GFCI, which will immediately blow if you try and connect that box!
Not true the box is specifically designed to work on GFCI outlets
See Here
About Fifth Wheel Group
