Lantley
Nov 17, 2016Nomad
jaycocamprs wrote:Lantley wrote:enblethen wrote:
Device looks very similar to Progressive Dynamics cheater box. It specifically says no GFCI and receptacles must be on separate circuits.
Cheater box
It is nothing like a cheater box. This unit is hardwired into the RV. Two different animals.
So it is a transfer switch that transfers just 1 AC unit off the main trailer power over to the dedicated 20-amp circuit. And by transferring both hot and neutral, the load thru the GFCI is the same on both hot and neutral
Yes and it works....
Once you grasp, believe,understand,trust that it really works.
You will hopefully see the game changing possibilities of the device. I did and It will change my camping destinations. OPtions always have options. Being able to use both AC's on a 30 amp sites will give me lots more options.
About Fifth Wheel Group
