Sam_Spade
May 10, 2017Explorer
guidry wrote:
If the wattage is the same a converter plug will work.
Probably not.
30 amp service is single phase 120 volts.
50 amp service is two phase 240 volts.
IF.....the gen has any kind of 220/240 3-wire (or 4 wire) output on it, an adapter might be possible.
If....the generator does NOT have any 220/240 outputs, then no it won't work.
About Fifth Wheel Group
