cimac
May 12, 2017Explorer
If you are getting the Champion Model #100161, It comes with both 30 amp and 50 amp rv plugs. You should get 30 amp max on the 30 amp plug and 30 amps each leg on the 50 amp plug. The question/answer section of their site says it should run two rv air conditioners on the 50 amp plug side. My 4000/3500 Champion will run one 15000 btu ac with no issues.
About Fifth Wheel Group
