Sam_Spade
Jun 12, 2017Explorer
Plumber101010 wrote:
.....what will I lose using Hondas 4000 versus Champions 7500?
You lose the ability to run 3500 watts worth of equipment......which you likely don't have anyway.
P.S. I went back and read your original post.
A 5th wheel with 50 amp service likely has TWO air conditioners and you will NOT be able to run both of them with 4000 watts.
BUT.....all but the lowest end 5th wheels should come with a built-in generator so you likely won't have to worry about getting the wrong one.
If this will be a new unit, ASK what the max. AC draw IS.....if it doesn't already have a proper generator on board.
About Fifth Wheel Group
