dedmiston wrote:
Nice looking rig. I'm glad to hear you didn't have more gremlins. Usually a new rig has a long list of warranty items.
I like your convenience center. Did you remove a partition to fit your 50A cord like that?
I have to give you a hard time though: Is that actually three cans of WD40? That's more than a lifetime supply.
I did not remove any partition. It's a passthru- kinda. The other side is a full rubbermaid bin width. Where the water is it angles in a bit, but is open all the way through. It's 2 bins deep before it angles, then there's about 3-4' of passage that's hard to reach unless you pull everything out. It may eventually our location for the bag chairs. I have heard of people reworking this area because they say there's a ton of wasted space behind that angle. If I get bored over winter maybe I will see if I can pull it off and rework it a bit. Angles are the devil for storage.
If you look close I have my surge protector hanging on the right of the cord. The other clips are for the 50-20amp and 50-30 amp adapters
The three cans are Slide lube, dry window lube and rubber seal lube/spray. They are in the white bin now.
I may rework the area in the future. There's a lot of wasted space in the truss area that I could possibly use somehow too.
Hose storage.
edit: fixed width
