tooldad1041
Feb 11, 2020Explorer
plumbing and HVAC are soon to be installed. We have a rooftop mounted AC to be installed. We have an underbelly water tank so we will route plumbing from the tank soon. The section of flooring that is over the tank is just sitting there at this time. We will have a propane furnace, again from donor camper, which will go under the fridge, also from the donor camper.
Using the power converter box from the donor camper. Wiring up 110v and 12v. All lighting is 12v so it can be run on battery or shore power. 110v was run through framing members in the floor inside 3/4 conduit and junction boxes. All 12v wire is sheathed and insulated with grommets where it passed through framing members.
Windows are to be installed above each fender, and one in the loft. The will be framed in with 1x2 tube steel as everything else is on trailer.
The donor camper only had one small window, so we elected to just make that work. We did find some windows on marketplace, however they were white frame, and with the rest of the trailer having black trim, we elected to stick with one window.
No shortcuts. We are even adding a DVD double din 12v stereo along with a 12v/110v tv so the kids can watch TV if stuck inside on battery.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
