routemaster
Feb 03, 2016Explorer
the bear II wrote:
I'm guessing you mean the tires are very close together. There are several causes:
> Spring issue Broken, bent, loose, worn shackles
> The pin that aligns the axle has sheared off. This pin is where the spring pack meets the axle.
> Bands inside the tire are broken and the middle of the tread is bulging. The tires should look flat across the tread, if there is a significant bulge in the center then the bands may be coming apart.
> Bent axle
See how close the shackles are to hanger.
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
