AH64ID
Mar 22, 2014Explorer
REM13 wrote:
I went the 3/4 ton route in 2007 and realized quickly that I made the wrong choice. I now own a 2012 3500 SRW and would not consider another 3/4 ton no matter the size of unit. I suggest at minimum a 3500 SRW diesel.
What is your basis for thinking you made the wrong choice?
Your 2007 3/4 ton and 2012 1 ton have the same frame, brakes, axles (assume 2007 was diesel), wheel and tire rating.
The only difference is the rear springs are 7% stiffer on the 2012 vs the 2007, the rest is identical.
On EDIT: I just realized I made the assumption your 2007 was a Dodge.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
