Lou_D's avatar
Lou_D
3rd AC
We have a 2 month old 5th wheel. It has 2 AC's but in this South (and I do mean FAR South...literally will be in Pharr in a couple weeks currently in Houston)....these two just aren't cutting it. Am considering a 3rd AC be added. Considering ducted. However, can the existing ducts from what would be the middle AC to the rear living room be closed off some way, and the new 3rd AC be tied into those ducts (AC would be basically over the couch in rear of RV)?
  • jdc1's avatar
    jdc1
    Explorer II
    Electrical supply would be your achilles heal. You would need to run another 20A supply form the 110V distribution panel to the AC.
  • Lou D, if not set up for a 3rd A/C, ducting and wiring will be an issue.
    It would be great if you added a signature line to your post letting people know what kind of RV you have. Fill in any info you want to show and then scroll down to the bottom and click save.
    Ken
  • I have the same issue with 2 AC's not doing the job. I use a free standing fan in the living room and am thinking about trying one of the free standing AC units that I see advertised for around $450.
  • If the RV is not designed and set up for the 3rd AC including ducts and electrical then it could be a big job.
    Is the RV 50A? Bigger ACs, window AC, mini split?
