IMHO there is only one "best of both worlds" that is the AISIN with 3.42's towing up to the 27-28K range. RAM even agrees just look at their chart.
My Son's Limited had AISIN with 3.42's and on a grade with around 27-28K combined the truck took off no issue and no axle wrap. My 11 HO RAM Dually had 3.42's and was great towing 28K, only exception was starting on a grade with the 68RFE it did struggle a bit. Towing at 60 or so the rpm was about 1,750 in 5th a perfect rpm basically the same as my current 15 with 4.10's in 6th.
3.73's just don't fit in the perfect world like the above do.
Chart says 29.300# combined for a 15 Dually 4x4 with AISIN.
