TxGearhead wrote:
3.73, Aisin in 5th at .77 overdrive, equals 1900 rpm at 65 mph.
3.73, Aisin in 6th at .63 overdrive, equals 1555 rpm at 65 mph.
3.42, Aisin in 5th at .77 overdrive, equals 1743 rpm at 65 mph.
3.42, Aisin in 6th at .63 overdrive, equals 1426 rpm at 65 mph.
385 HP at 2800 rpm and 900 ft lb torque at 1600.
I guess if you want to get higher HP the 3.73 looks better. The 3.42 in 6th gear is well under max torque.
My 3.42 works OK locked out of 6th, but the 3.73 looks like it would have higher HP. Something of a trade-off between more HP/torque and lower rpm for fuel mileage.
On edit using what I note in following post. 4th gear (1:1) and 3.42's provide 2224 RPM climbing a mountain pass a 60 MPH. 24500 LBS runs right up a 6 percent grade in 4th without a problem(except curves in the road). Why do some not want to use the gears provided in a 6 speed tranny. Run up a mountain pass at 60 MPH is 3rd gear(1.34) would have the engine turning 2980 RPMs, busy but doable. On highway 152 from Gilroy, Ca over to I-5 I was down in 3rd pulling a really windy slower section of the little pass, that was with the old 5th wheel and 22K combined.
I towed for years with a 2001.5 with a 47RE that was 325/650-700 at the rear wheels but was gear bound by only 4 forward gears, and much wider splits.
The difference with having 6 speeds forward is night and day.
I edited earlier post 60 MPH in 6th is around 1300 RPM.
I will take the low RPM's of 3.42's at 70-80 MPH any day over any lower gear ratio.
I tow at 800 pounds under the rated combined weight of 25,300 for CC 4x4 Aisin 2015 and just do not see an issue that I would address with a different gear ratio.
Disclaimer, before purchasing the truck I was sure that I would have gotten 3.73 if they were available. I now know that would have been a mistake, as they are not needed within the ratings of the truck.
And I repeat again I will take the low RPM's of 3.42's at 70-80 MPH any day over any lower gear ratio.
Chris
