cruz-in's avatar
cruz-in
42 Foot Toy Hauler with 2063 Pound Dry Pin Weight?
Hi All,
Evergreen's new toyhauler, the T3914 tips the scales with a dry wieght of almost 15K and a dry pin wieght of just over 2K.
42 foot, 15K Dry wieght, just over 2K dry pin wiegth....
Seems like a light pin wieght as loading the unit in the rear garage could possible bring the pin wiegth down to 1500 pounds....even considering all the stuff one would add forward of the axles...
Do you think they did this to accomadate the 250/2500 crowd?
Just found it interesting, this large a tow hauler with that light of a dry pin wieght.
You all's thoughts?
  • When I was looking at fifth wheels for a SRW, I found simple rule of thumb was that triple axles require a DRW tow. As others have posted, once you add fluids, options and gear you will be closer to 3500 lbs pin weight.
  • Real world you will be closer to 25% pinweight - of an empty toyhauler. All the heavy stuff occurs on top and behind the axles, which while raising the gross weight, it lowers the pinweight. If it has an onboard genset, it is likely in the 4k+ range empty. The 2k pinweight on the brochure is salesmans speak.
    TESLA Brochure doesn't list it, but the two listed are 2700 and 3300 lbs.
  • My 42' loaded, but empty tanks, has 15640 on the axles and 3080 on the pin. Similar 3-slide floorplan to the model you referenced.
    Truck has 12280 on its 6 wheels - full fuel tank.
    Would I put this on a 3/4 ton? No, but there are a lot of people who feel luckier than I do who would.
  • Has anyone purchased or weighed a Tesla T3914 yet?
    I'm considering that model and would love to see some real world numbers.
