waterfowlhunter
Dec 31, 2015Explorer
Timay wrote:
I believe that is a 50 amp 90º female twist-lok cord cap - should be able to find it at Graingers, if one is in your area. If not, try an electrical supply house - they are generally wholesale only, but they will be able to send you to the proper place.
Don't think those were made specifically for a 5th wheel - we electricians use them for many other things. You might stop in at a local electrical contractor and explain what you are looking for. They will go straight to the NEMA Twist lock chart and find it from there.
Tim
I tried Grainger, they carry the Hubble brand and want over $300 for the straight connector and that is with my electrical company discount. Then they got an attitude with me when I told them the straight ones at Amazon are under $40 at times. They also refused to even try to research a 90 degree one for me. They lost most of our business due to their attitude with me on this. I have also checked several marine suppliers and have found some 90 degree connectors that fit but only are 3 wire and do not have the outer ground connection only the 3 blade connections.
About Fifth Wheel Group
