Road_Phantom
Apr 18, 2021Explorer II
50 amp in a 30
If I plug into 30 amp service at the RV Park, what can I run. Obviously, I wouldn't attempt to run both a/c's, but if I can get by with one, the park would be convenient for us. Thanks.
pianotuna wrote:
Hi Valhala360,
That's a nice write up on hybrid inverter/chargers.
However, do please realize that it is not "voltage support" (a la autoformer).
It is possible to limit the incoming amperage. Since I'm 30 amp, I limit at 24. If I'm boondocking, I drop that to 12.
If load support is active and the batteries drop too low, then the shore power breaker will trip. DAMHIK.
After this summer, I'll be moving to a 7.2 KWH usable capacity battery bank.
In the days before I had load support, I would do double conversion--plugging in only the converter--and running the RV from a 2500 watt inverter, powered by the
875 amp-hour (3.2 kwh usable) battery bank.
