v2kExplorerApr 28, 201850 amp plugWe have a 2018 Eagle 5th wheel and the 50 amp cord won't hook into the camper. We used the camper a couple of times last year and it would hook up ok then. Has anyone else had trouble with the pow...Show More
SailingOnExplorerApr 28, 2018a little corrosion on the metal surfaces causing the plug to bind? Fine sandpaper or steel wool then WD-40 or dielectric grease might do the trick.
Related Content3 prong 50 amp plug to 4 prong 50 amp ????30 amp camper/50 amp plug and cord50 amp RV plug50 Amp plugging into 30 amp service30 Amp VS 50 Amp
