- rattleNsmokeExplorerAyup, I mis typed and you beat me to the correction. Try my original link again.
Mike - DazedNConfusedExplorer
rattleNsmoke wrote:
I got mine from this distributor. It's the best price I could find.
clicky
Mike
Did you mean this instead? http://www.makariosrv.com/ That's a good price, btw.
-DNC - rattleNsmokeExplorer
- NorskemanExplorerGot mine from tweety's.com EMS-HW50C
http://tweetys.com/electrical-management-system-hardwire-50.aspx - DazedNConfusedExplorer
esfd243 wrote:
Anyone have a part # for the 50A unit? I already had a CG buy me a new microwave and a/c after an electrical problem.
Amazed you could get a CG to replace equipment. Good on'ya.
Here is the part direct from the manufacturer with all the tech specs: clicky
Here is the part from Amazon (cheaper than buying direct): clicky
Both of those are with the remote display -- which is actually very nice to have since it will display the error code if the unit cuts power for some reason (low voltage, surge, pole wired incorrctly, etc.) as well as how many amps you're pulling, line voltage, etc.
I let the dealer install mine before I even brought the unit home. Charged me $75 for the install.
- DNC - TakingThe5thExplorerI have the Progressive with remote. EMS-HW50C.
- esfd243ExplorerAnyone have a part # for the 50A unit? I already had a CG buy me a new microwave and a/c after an electrical problem.
- kennethwoosterExplorerYep doing that right now. Works perfect.
DazedNConfused wrote:
tvman44 wrote:
Yes, we do it all the time. Hope you got the Progressive Industries unit. :)
Me, too. These are built 5 minutes from where I live. :)
X2. Works great. - NorskemanExplorerUsed my 50 amp unit on a 30 amp service last week - unit worked good (Progressive Industries 50 Amp Hard Wired EMS with Remote Display).
Voltage at the RV park dropped below 104 volts many times. Probably saved our AC unit.
After a couple of the voltage drops I ran the frig on gas the rest of the time.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
