I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
In theory what you propose will in fact work. An alternative that would be less complex would be buy a 30 (male) to 50 (female) amp adaptor. This adaptor powers up both 50 amp hot lines at the same phase and would only require your current generator set-up. Of course you are now limited to the twin Hondas capacity (3200 watts) so no dual AirCon operation.
