I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
I agree with hmknightnc. In theory it'll work unless you have a 220 load in the 5th wheel. We have a dryer in our MH that runs on 220 so it wouldn't work for us. Your 220 or the difference between the two hots would vary slowly as the frequency of the two gens is slightly different. The voltage would slowly vary from 0 to 220.
