I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
The two hot legs are separate, but they share a common neutral. So you would be tying the neutrals of both generators together. Don't know what the two generators would do with the phases out of sync and the neutral connected but I don't think I would try it without a go ahead from the generator manufacturer.
