I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
NO,NO,NO,and did I say NO. Where I use to work we had two 700kw 480v 3p Cummins gen sets running in parallel with out a common load controller. They were a head ache. Aircraft use a fancy thing called a freq./load controller for generators running in parallel.
