I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
Here is some info I found about paralleling generators. Although this is about doing so in a power plant, what you are doingis making a little power plant.
