bama5er
May 22, 2014Explorer
50 amp wiring
I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
nylyon wrote:More than likely your gens neutral is tied to the utility neutral some where besides the transfer sw. contact points. Probable straight to the neutral bar. I have install many gens and transfer sw.s
Well, all I know is the transfer switch on my house cuts the HOT only. When I test my generator it *ties* the neutral to the power grid (a lot more than another generator I'll tell ya that) with my generator and the test is successful every time.
I don't see where this is any different, if there's no circuit's using both legs of the 50A service.
