bama5er
May 22, 2014Explorer
50 amp wiring
I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
KD4UPL wrote:
Even if you hooked up what your proposing and didn't burn up a generator you still have the possibility of overloading the neutral wire. If you've got 4 2 kW gen. hooked up that's 8,000 watts potentially. At 120v that's almost 67 amps. That's way too much current for the neutral.
