bama5er
May 22, 2014Explorer
50 amp wiring
I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
hmknightnc wrote:
Folks, he's got a 50 amp service RV which is actually two 120 volt hots at 50 amps each or a total of 100 amps on the common neutral. A 50 amp RV can handle 12,000 watts.
