I have a question concerning 50 amp wiring in fifth wheel and generators. My idea is that if the two 120 volt lines are separate, meaning no device will use the 2 hot wires, could I run two separate g...
If the generators have a gfci it will not work. The load on the neutral will be unbalanced and trip the gfci. The 30/20-50 combines only work if there is no gfci on either plug.
Either get 2 eu2000's, or equivalent, or one bigger generator.
