nole_trainer
Aug 14, 2014Explorer
garysol wrote:
If you have a 50amp to 3 prong adapter that should be all that you need to plug into your 20a home electrical. If your extension cord is this or very long that could be causing issues. With the A/C off can you run your TV? Since you have 2 A/C units I assume one may be a smaller unit. Have you tried to fire up the small one only?
AC off, everything runs fine. I think garage circuit I'm on is not 20amp, that is probably the prob. Thanks! To top this off, my home AC is not working when we got to the house, so I thought "No problem, will sleep in RV with the boys". ugghh!
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
