DutchmenSport
Aug 14, 2014Explorer
You may get a little more "zing" from your 20 amp home plug if you make sure everything inside the house is turned off that's attached to that circuit breaker ... all clock radios, night lights, appliances, lights... everything. Unplug it all. Although some electronics, like DVD players and Satellite receivers may appear to be turned off, they are really not truly "off" unless they are unplugged. Although the electric draw may be tiny, if you add up all those "tiny's" they can account for a few amps. That is included with everything on the one circuit breaker you are attempting to run your camper on. Unplug everything on that circuit inside the house (and outside), and see if that helps.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
