Golden_HVAC
Aug 14, 2014Explorer
Another thing.
If your RV battery is pretty low, then plug in the RV charger at least to recharge the battery before your trip, so that you will have power once you get there. It might be the battery charger using 5 amps and tripping the already loaded house circuit breaker.
Some new code requires that ark interrupting circuit breakers are used. These might trip due to the RV being plugged in. it is sort of like a GFI circuit breaker, however it detects arks, such as when a extension cord is sparking, and trips instantly, even at less than the amperage rating on the circuit breaker.
Fred.
Fred.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
