john_bet
Aug 15, 2014Explorer II
Here is my advice. You need at minimum a 20 amp very short run dedicated circuit just for the RV. If you can not do that then a dedicated 30a amp RV plug and circuit with at least 10/2 with ground wire. If it is a long run from your panel then consider using 8/2 with ground wire and a single pole 30 amp c/b with either wire size. JMHO.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
