Cummins12V98
Aug 19, 2014Explorer III
Bumpyroad wrote:Cummins12V98 wrote:
Exactly what I have said before!
No different than buying POS Chicom tires instead of quality US made for a bit more.
so you are considering to only put in what is necessary and saving some money is comparable to buying inadequate tires? nonsense.
actually if I were doing it, I would just run 10/3 wg to a 30 amp breaker and just leaving one wire as a spare. then if it ever was needed I could easily add one breaker and have dual 30 amp service, which is adequate for everything. we are just talking about occasional use pre trip, etc. and not living in the desert 24-7-365/
bumpy
Yes IMHO it's better to go the extra mile if it's not much more than to wish I had done it later.
30 or 50A breaker is not much difference nor is it going to break the bank going from 30 to 50A wire. Labor is basically the same.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
