ReneeG
Aug 19, 2014Explorer
Cummins12V98 wrote:Bumpyroad wrote:Cummins12V98 wrote:
Exactly what I have said before!
No different than buying POS Chicom tires instead of quality US made for a bit more.
so you are considering to only put in what is necessary and saving some money is comparable to buying inadequate tires? nonsense.
actually if I were doing it, I would just run 10/3 wg to a 30 amp breaker and just leaving one wire as a spare. then if it ever was needed I could easily add one breaker and have dual 30 amp service, which is adequate for everything. we are just talking about occasional use pre trip, etc. and not living in the desert 24-7-365/
bumpy
Yes IMHO it's better to go the extra mile if it's not much more than to wish I had done it later.
30 or 50A breaker is not much difference nor is it going to break the bank going from 30 to 50A wire. Labor is basically the same.
If you have the setup already. In our case, our box is not setup for an additional breaker, plus a separate one would have to be added to support the 50amp, so it would cost us over $2K to add it. We are not electricians so we have to rely on professional service.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
