Water-Bug
Aug 19, 2014Explorer II
Even if you don't have room in the box, it isn't a $2k proposition. You simply remove two breakers and use the space for the feed/breaker to a subpanel. The lines/breakers that you removed are then wired to the subpanel along with your new 50 amp breaker.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
