Cummins12V98
Aug 24, 2014Explorer III
avvidclif1 wrote:
The "RV" 50a outlet is a standard NEMA 14-50R outlet. Same one as used in houses. If wired to code there are no problems. I would have been talking to the electrician about his wiring. He probably left off the neutral.
I agree something sounds fishy.
dancoppins,
I will bet if you get the story straight your friend was comparing a 30A 220V house outlet where you have two hots and one neutral to a 30A 120V RV outlet where you have one hot one neutral and one ground. Probably used a 30A RV receptacle and wired it to 220V.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
