BillPenn's avatar
BillPenn
5er sways over 65mph
Have a 2014 Dodge 2500 Crew Cab 6.7L Diesel pulling a 32’ Thor 5er (dry weight 11500). New truck pulls great with plenty of power to spare. Only one problem, if I get over about 65 mph the rear of the trailer will start to noticeably sway. Can’t feel it in the truck, but you can see it in the mirrors. If I slow to below 60 mph it will stop. I replaced my tires this year with new Good Year ST225/75R15 load range E, and have them inflated to the recommended 55psi. With the trailer hooked up it sits fairly level, maybe a little down in the front. Any suggestions on stopping this, or is it normal? Not looking to do 90 but would like to maintain the speed limit.
  • Once I had a fiver start swaying while going downhill. I checked and found the pin box bolts had loosened. I tightened them up and the problem was resolved. Easy enough to check.
  • I've also wondered about checking the trailer's alignment. You would think that you would see issues sooner, but still makes me wonder.
    For all of the 65 is the max speed folks-- most ST tires are only rated to 65mph, but their are some that allow you to go faster. Goodyear has the +10mph published; Maxxis responded to a dealer inquiry with similar information; and Greenball ST tires have a 75mph speed rating.
  • I'm also in the group that believe the tires are under inflated. What "manual" recommends that? Inflate to max pressure recommended on the side walls. That's the fastest, simplest first step.
  • Milt wrote:
    Maxxis has an E rated tire in that size. Pressure should be around 75 psi.
    Milt
    I run 16 inch Maxxis E rated tires. They call for 80 pounds pressure.
