Thermoguy
Aug 06, 2022Explorer II
The only thing that matters here is if the trailer is within the vehicles payload numbers. Upgrading tires, suspension, adding air bags, just makes towing within the vehicles payload more comfortable and safer. So, can an 1/2 ton pull a 5th wheel, the answer is yes. But, that 5th wheel must be within the weights the 1/2 ton can handle. I was looking to buy a 1/2 ton to tow a gooseneck trailer with a 1200 lb hitch weight. So, they are out there and 5th wheels are out there. But, just because it says 1/2 ton towable, doesn't mean it is. Look at the trucks payload. Also, does anyone make a hitch for that particular model? I think the 5.5' bed limits your options very fast. The 6.5' bed has more options. If he was buying a truck, best to buy something you can upgrade trailers later. 3/4 or 1 ton is a better choice if you plan to tow for many years. I'm at a park today and there is a public RV dump at the end of the row. All the RV's driving to the dump, I have seen multiple trucks with overweight trailers, or at least rear bumpers that are low to the ground and headlights pointing to the sky. Either their weight distribution hitches are incorrectly installed or they are overweight, or both...
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
