Thermoguy
Sep 30, 2022Explorer II
Anyone that says a 1/2 ton can not pull a 5th wheel is incorrect. People are doing it as has been stated on this site many times.
The only issue is that the 5th wheel must be within the payload limitations of the truck. That is the issue. They make 5th wheel hitches for 1/2 ton trucks, I looked them up. I was and still am considering a 1/2 ton truck down the road - for a trailer with a 1200 lb pin weight fully loaded. I have looked at various 1/2 ton trucks a couple years back, some were OK for that payload, some were not. If its within the payload - not at the max, then it would be OK. They do make small 5th wheel trailers.
We can discuss things like the short wheel base on the 5.5 bed, that would be an issue I would stay away from. We can discuss the thin materials that make a 5th wheel light enough to be 1/2 ton towable, that I would agree with. But if it's within the ratings, its not the end of the world. It does limit the owner to not being able to upgrade, probably has small tanks, etc. But, it can be done.
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
