usmcshepherd's avatar
usmcshepherd
Explorer II
Aug 02, 2022
5th wheel & Half-ton TV Thoughts
Hello all,
I have a friend who has a F150 who is currently towing a 30ft bumper pull trailer who is looking to move up to a 5th wheel. I am concerned that while the dealership says he'll be fine that he'll have clearance issues with his small 5'5" bed (his F150 is a crew cab). He has already upgraded his tires and suspension so handling the pin weight (he's looking at the lighter halfton 5th wheels with pin weights around 1400lbs). If anyone has any thoughts or experience when it comes to clearance issues and hitches it would be greatly appreciated. Thanks
  • Is your friend in Colorado as well? I can't imagine that any 150 would have the cooling capacity to pull a 5er over the mountains. I have a 19 Expedition MAX that both tranny and engine temps go above 240* when towing my 7000 pound boat over I70. Higher profile and more weight is going to be a no-go, even if he had the payload to do it.
  • It’s a 5.5’ box which means it’s not a HDPP (they’re 6.5’) and doesn’t have enough payload or rawr for a 5th wheel. This is coming from a guy that tows a 5th wheel with a 1/2 ton that’s in my signature.
  • "the dealership says he'll be fine..."
    Of course they do! Dealer wants to make a sale. He won't be fine with 95% of all 5ers. TOO much pin weight. One can modify their truck (even those of us who are not automotive engineers) but one can't increase the manufacturer's max weight. What I believe your friend really did was modify the truck to make it level.
  • 1) What does the payload sticker on the door say and what is the actual CAT weights for the truck loaded with passengers and gear ready for travel?
    2) Is 1400lb pin weight based on an empty trailer or 20-25% of the GVWR?
    - If it's 25% of the GVWR, he may be fine if he has a high payload 1/2 ton truck but that's a tiny 5er (like 5-6,000lb).
    - If 1400lb is the empty weight, expect to be up around 2000lb or more once loaded.
    2000lb pin weight is getting iffy for a 1/2 ton truck. Add in a couple hundred for the hitch and 3-400 for passengers and even the beefiest 2500lb payload 1/2 ton trucks are maxed out without putting anything else in the truck.
    Yeah, he will have to be very careful with a 5.5ft bed. Doable but don't be surprised when he buys a new rear window for the truck.
    What exactly is he hoping to gain by going to a 5er? While 5ers tow nicely, a properly set up bumper pull should not be a white knuckle ride by any stretch. The advantage is hitch weights for bumper pulls should be in the 12-15% range rather than 20-25%, so they tax the trucks payload less.
    If you want a 5er, it makes far more sense to upgrade to a 3/4 or even better a 1 ton truck (3/4 can even be marginal by the time you get north of 8-10k lbs).
  • About the only option with that short bed is a Sidewinder style pinbox that turns at attachment point on FW.
    That truck is just not best option. Since he has upgraded tires/suspension, it may work, but keep in mind, if looking at pin wts of 1400 dry (brochure) wt, that will increase a bunch, could end up closer to 2K when loaded to GVWR of FW.
    Jerry
