Endricken
Oct 08, 2020Explorer
Well, my Goosebox did NOT protect my Fiver. When I installed the Goosebox the friend who helped me was a big guy and over torqued/broke a bolt. Our fault but when I contacted Reese/Lippert they said they would send a new one. They NEVER did, but of course I did readily find a replacement bolt at the Auto Parts Store.
Just less than a year since installing the Goosebox (did they ever fix the airbag valve that puffs out the air so you have to refill it after almost every tow - which was not easy to do...? or deleted the requirement to grease the coupler every time you hitch up?)
Anyhow, I hit a really bad pothole in west TX I-10 and it actually bent the movable part of the Goosebox slightly so it would rub against the fixed part. Within days and 1000 miles of towing my Fiver was bouncing on my Truck's bed rails...
Broken front H Frame Pinbox member. I contacted REESE/LIPPERT under warranty as it was less than a year JUST to send me a new one and they refused!
I ended up going back to/purchasing a STAR Performance Goosebox adapter (with built-in glider motion). Now that my front frame is rebuilt with stronger steel I have had no problems other than some chucking on America's Worst Interstates.
However I did have to get upgraded Easy Rider Shock System brackets thanks to these horrible sections of road as the original Easy Rider Brackets were a little lighter in construction and one of them was bent despite the presence of full size shocks!
When we will see infrastructure improvements???
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
