SUMRX4's avatar
SUMRX4
5th wheel adapter for goose neck
Just something I have noticed around in campgrounds but why do some people convert their 5er to a goose neck? Is there a difference in towing or is it usually done by folks that own additional goose neck trailers so they don't need to switch hitches in truck bed?
Just curious
  • garyp4951 wrote:
    The Reese Goosebox, and Gen-Y are the new kids on the block, and are said not to damage the FW frame.
    But do manufacturers recognize them or still say no to a gooseneck?
    Reese and Gen-Y may say they are good, but if something happens will your trailer company tell you tough luck?
  • The Reese Goosebox, and Gen-Y are the new kids on the block, and are said not to damage the FW frame.
  • Also you are supposed to use safety chains with a gooseneck hitch. Although it is questionable how many “forget” or never know that.
  • A goosneck where the ball is at the floor of the pickup bed, creates a longer leaver arm on the trailer frame. If it's a light weight trailer with an overbuilt frame, that may be OK. If it's heavier and not built so well, it can be a problem...particularly if you are on rough roads. These variations in weight and driving conditions explain why some people go years with no issues and others quickly break something in the frame.
    You may occasionally see a mount where it's a gooseneck ball but on a raised frame, pretty much the same height as a regular 5th wheel hitch. That shouldn't have any impact on the stress the trailer frame sees as the lever arm is roughly the same.
    As to why? Most already have a gooseneck ball in the truck and it takes up very little space when not towing...vs a big heavy hitch that eats up a 1/3 of the truck bed when not towing.
  • Probably people who have other gooseneck trailers. And/or those who grew up with or worked with farm, stock, and implement gooseneck trailers. But those are designed specifically for the gooseneck hitch.
    The rigid gooseneck adapters for 5ers put stresses on a trailer frame that a standard 5th wheel hitch does not. And some manufacturers will void the warranty on a new 5th if you use one. But, having said that, many do it any way and seem to have no problem with them. The Goosebox (with air ride and shock absorber) is the only one I have heard of that is actually acceptable to some manufacturers.
  • He may be referring to a "goosebox" which does not cause issues with your chassis warranty. The one I am thinking of is made by Reese, however there is another out there that I have seen but do not remember the manufacturer.
    Oh, and I would use it (if I could) so I do not have to remove a 250lb fifth wheel hitch in/out of my truck bed if I wanted to use my pickup as a... well... pickup.
    //KMac
  • jdc1's avatar
    jdc1
    Explorer II
    And then their are those that think a goose-neck is "all that".
  • Most likely ...multiuse
    But there are some that think it is better
    Biggest issue is 5th wheel pin box frame/structure are NOT designed for that type of strain/pressure
    Just look at how a gooseneck trailer is built vs a 5th wheel overhang frame
