CoffeePat's avatar
CoffeePat
5th wheel brakes and breakaway switch
On my maiden voyage return trip, the "breakaway pin" inadvertenly falls out. I thought I was paying attention, but it seems to jerk quite a bit anyway so I didn't notice for maybe 30 miles. (don't know) This is on a 2010, 35 ft LZ 5th wheel. I'm pulling it with a 3/4 ton Power stroke diesel. I guess maybe the brakes weren't adjusted properly because 1 shoe was completely gone, but the other 3 still had almost 1/2 the pad left. Wierd. I plan to replace all 4 brake backing plates, but only 2 of the drums, others look fine. SOUND OK?
Also, should I be able to pull the breakaway switch pin out by hand? I cannot. Maybe its supposed to be really tight or it's melted into place.
  • My breakaway switch pull out with a good pull. You don't want it so loose that it falls out. It may be that when the pin was put in it was not put in all of the way. JMO
