BB_TX
Feb 25, 2022Nomad
Many people do like a gooseneck hitch. But if you do choose that then go with the Goosebox as it is approved by Lippert so as not to be a problem with frame warranty. You do have to use safety chains with gooseneck hitches in some states since it is a ball hitch. And they are a little bit harder to hookup since you have to be more precise in the alignment of the ball and hitch.
Most people use a conventional 5th wheel hitch. The air ride hitches are considered the best as far as ride since they they have air bags to soften the road shock. Downside is the costs. Some use a standard hitch with an air ride pin box to soften the road shock. Less expensive than the air ride hitch.
As far a 5th wheel hitches, each brand has their fans. B&W, Reese, Pullrite, Curt, etc. All are good hitches and you can't go wrong with any of them as long as you don't go with their lowest price models. Hookup is easier than a gooseneck since the 5th wheel hitch is self aligning. If you are within an inch or so the pin will slide into the hitch slot and stop when it is fully in.
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
