Durb
Feb 25, 2022Explorer
Hitches generally come in two styles, soft joint hitches (air hitches) and solid hitches. There are also variations of pin boxes. My guess is your Solitude will come with a MORryde pin box which is designed to quell chucking forces, a fine product.
I would suggest you consider how you will use your trailer as you full time. If you are going to pull it south in the winter and park it, then north in the summer and park it, then a solid hitch would be fine. If you are planning to tote the trailer all over the country, then an air hitch would be worth the additional cost. The air hitch will provide towing comfort, additional safety, less driver fatigue, and shock protection for both your trailer and truck.
My suggestions: Solid hitch - B&W Companion per above posts. Air hitch, Trailer Saver BD5 set up for your puck system.
Congratulations on your new trailer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Aug 02, 2026
