RCMAN46
Feb 25, 2022Explorer
Cummins12V98 wrote:RCMAN46 wrote:
Suggest you take a careful look at the Reese M5 5th Wheel Trailer Hitch for Ram Towing Prep Package - Single Jaw - 27,000 lbs.
If you look at how the head is attached to the base you will not see the tall vertical posts that B&W uses.![]()
Click For Full-Size Image.">Reese M%
Does it have the head pivot point several inched below the kingpin connection like the Chinese Made CURT does that is known for causing chucking?
Where is that REESE made?
If you took the time to lookup the Reese hitch you would find the pivot point is virtually in line with the king pin.
About Fifth Wheel Group
19,025 PostsLatest Activity: Oct 09, 2025
