mr__ed
Sep 03, 2016Explorer
steadfastrock wrote:
You need to tell us what hitch you have. In general, you should lift the weight off of the hitch before pulling pins.
I agree, and you may need to move the truck ever so slightly fwd or backwards. I found that usually worked for me. When I mentioned moving the truck, I meant doing so without moving the fiver. If you have the emergency brake engaged, you might try releasing it and letting the vehicle find its own point when the pressure is released. That has often worked for me, also,
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
